Từ việc này, em chợt nghĩ là có cách nào làm tương tự với mpd không các anh nhỉ?
Khi start mpd nó sẽ tự động stop vài service nào đó. Khi stop play mpd nó sẽ restart lại?
Đã có Cantata 2.3.3 ạ.
Kể từ bản 2.3.3. Tác giả không compile cho Windows nữa. May mắn là có một anh dev tốt bụng đã làm giúp.
Many thanks to Barippi!
https://www.mediafire.com/?o0ez1g7huaoo7qo/
More info:
https://github.com/CDrummond/cantata
Changelog 2.3.3:
  1. For Opus files, use R128_TRACK_GAIN and R128_ALBUM_GAIN to store replaygain values.
  2. Remove user-agent checking when serving local files, this is easily fake-able and breaks playback to forked-daap (and mopidy?)
  3. Add '.opus' to list of recognised extensions for local files.
  4. Initialise network proxy factory when starting.
  5. If artist, album, and title are empty in replaygain dialog, then show filename in title column.
  6. Opus does not use replaygain peak tags, so do not write.
  7. Use same 'album key' for all discs in an album, so that playqueue groups them together, and shuffle by albums keeps them together.
  8. Remove confirmation dialog when saving replaygain tags.
  9. Fix saving 'Descending' order for smart playlists.
  10. When getting 'basic' title of song, also remove any 'prod. XXX', etc. values.
  11. Allow .jpeg as extension from cover dialog.
  12. Fix QMediaPlayer stuck with network streams - thanks to theirix
  13. Always show volume control.
  14. Fix 'Show Current Song Information' (i) toolbar button showing when interface is collpased and resized.
  15. When expand intrface, don't shrink width. Conversely, when collapsing don't expand width.
  16. In grouped style playqueue, only show album duration if there is more than one track from the album.
  17. Don't try to reduce brackets when showing album name and year.
  18. Add option to sort smart playlists by title.
  19. Change toolbar colours if palette changes.
  20. Add another qt5ct palette work-around.
  21. Don't stop library scan just because of failure in 1 directory.
  22. Handle empty VolumeIdentifier in MTP devices.
  23. Add more actions to search page results.
  24. For MPD>=21, use its albumart protocol to fetch covers.
  25. When copying tracks to a device, only update cache if configured to do so.
  26. Fix MusicBrainz disc ID calculation.
  27. When loading URLs via commandline use AppendAndPlay.
  28. MPRIS seeks command specifies an offset from current position.
NOTE There are no windows or mac binaries, as I will no longer be creating these.
Sao update ngày trên menu moode phiên bản cũ quá nhỉ?
Hiện tại có phần mềm nghe nhạc nào chơi được youtube hay zing, nhaccuatui không bạn?
Trên pi, Youtube thì có vài cách ạ.
Zing với nhaccuatui hiện giờ em chưa biết cách nào để chạy. Ngoại trừ chấp nhận chạy graphic / web browser trên pi o_O
henry7588
youtube chạy bằng cách nào bạn. Về OS trên Pi thi hiện tại cái nào ngon ạ, em đang dùng moode
quatmo
Mình giới thiệu Board mở rộng rất hữu ích cho anh em hay vọc, giúp chuyển qua lại giữa 2 OS trên Pi, ví dụ: đang nghe Volumio muốn qua Moode thì gạt công tắc rồi tắt mở lại là sẽ boot vào Moode. Đã test OK.
dungsin_lqd
Bộ chuyển sao thấy không gọn. Thò cái đuôi ra ngoài nhìn lởng lẻo ý. Theo em chơi hai thẻ ghim rút cũng ok rồi.
hungpmu
View attachment 346615 View attachment 346616
Cái này mua thẳng trên Ali hả bác hay mua qua dịch vụ ship hàng hộ? em muốn mua 1 cái mà chưa mua thẳng từ Ali bao giờ
quatmo
Mua thẳng Ali đấy bác, shipping tận nơi tốn 6000 đồng hải quan. Mình mua mấy chục món từ Ali rồi, chưa gặp trục trặc gì.
