# Controller Configuration
Four SAS SFF-8087 connectors, Support 16 internal SAS/SATA ports at 3Gb/s.
1.2GHz Intel 81348 XScale I/O processor
Onboard 512MB ECC DDR II memory
# Hardware Features
PCI-Express x8 host bus interface
Hardware XOR engine to offload parity calculation
Hardware RAID 6 accelerator
Full Height MD2 form factor
Optional on-board battery backup unit for data retention up to 72 hours
# Supported RAID Levels
RAID 0, 1, 1E, 5, 6, 10, 50, & 60.
# RAID Fault Tolerance & Robustness Features
- Multiple logical drive support enables combining different RAID levels on one set of disks
- Read Check table to avoid data read errors
- PerfectRAID™ technology for error handling and recovery of fatal, media and disk errors
- Support hot swap of failed drives and hot spares
- Automatic/Manual rebuild of hot spare drive
- Background initialization for instant drive availability
- Supports bad sector remapping
- Variable stripe block size support to meet various application requirements
- Synchronization can be scheduled periodically for RAID data consistency
# Web-based Promise Array Manager
Creates, deletes, expands, and converts disk arrays remotely.
Media Patrol and Redundancy Check scheduling
Monitors drive, array, enclosure status, and provides online event logging.
Email notification of drive, array, controller or enclosure events.
Remote management based on industry standard CIM/WBEM
Interface displays in 10 languages
CLI support
Remote firmware update
# Operating System Support
Microsoft Windows Vista, 2000, XP, Windows Server 2003.
Red Hat Linux, SuSE Linux, Miracle Linux, Fedora Core, Linux open source driver (32/64-bit).
FreeBSD, VMware 3.0.1/3.0.2.
# Platform Support
Intel IA32, EM64T, and AMD64.
# SuperBuild™ BIOS
Array configuration utility at the BIOS level
BIOS Boot specification support: boot system from any array
Flash-upgradeable BIOS for future upgrades
# Enclosure Management
SES-2, SGPIO, I 2C
# Physical Dimensions
16.7 cm x 11.1 cm (6.6” x 4.4”)
# Agency Certifications
UL, cUL, CE, FCC Class B, BSMI, VCCI, MIC, C-tick.
