Play được trên pi3 rồi các anh ạ
Cảm ơn anh @quatmo và anh @Thanhvo31 rất nhiều. Bước đầu vậy là quá ghê rồi. Mai em test tiếp ạ
Âm thanh rất hay.
Em kiểm tra services:
Âm thanh rất hay.
[root@rpi3 ~]# sstatus
-- Services Enabled --
UNIT FILE STATE
archphile.service enabled
lighttpd.service enabled
netctl@archphile\x2dnetwork.service enabled
netctl@wifi\x2dnetwork.service enabled
ntpdate.service enabled
rc-local.service enabled
sshd.service enabled
sudo.service enabled
tidal.service enabled
remote-fs.target enabled
10 unit files listed.
-- Services Running --
UNIT LOAD ACTIVE SUB DESCRIPTION
init.scope loaded active running System and Service Manager
session-c1.scope loaded active running Session c1 of user root
session-c2.scope loaded active running Session c2 of user root
session-c3.scope loaded active running Session c3 of user root
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
dbus.service loaded active running D-Bus System Message Bus
[email protected] loaded active running devmon Service
lighttpd.service loaded active running Lighttpd Web Server
sshd.service loaded active running OpenSSH Daemon
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running Login Service
systemd-udevd.service loaded active running udev Kernel Device Manager
tidal.service loaded active running tidal connect
[email protected] loaded active running User Manager for UID 0
avahi-daemon.socket loaded active running Avahi mDNS/DNS-SD Stack Activation Socket
dbus.socket loaded active running D-Bus System Message Bus Socket
systemd-journald-dev-log.socket loaded active running Journal Socket (/dev/log)
systemd-journald.socket loaded active running Journal Socket
systemd-udevd-control.socket loaded active running udev Control Socket
systemd-udevd-kernel.socket loaded active running udev Kernel Socket
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
20 loaded units listed.
To show all installed unit files use 'systemctl list-unit-files'.
