@linh0983
Kiểm tra kỹ rồi mà vẫn không lên được bác ạ
BACK END
config.txt >>> dtoverlay = allo-digione
cmdline.txt >>> ip = 192.168.11.113:255.255.255.0:192.168.11.1
ping 192.168.11.113
Pinging 192.168.11.113 with 32 bytes of data: Reply from 192.168.11.113: bytes=32 time=19ms TTL=64 Reply from 192.168.11.113: bytes=32 time=6ms TTL=64 Reply from 192.168.11.113: bytes=32 time=8ms TTL=64 Reply from 192.168.11.113: bytes=32 time=8ms TTL=64 Ping statistics for 192.168.11.113: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 6ms, Maximum = 19ms, Average = 10ms
Nghĩa là BACK END ngon!
FRONT END
vsound.service - Audio over Ether Virtual Sound Card
Loaded: loaded (/usr/lib/systemd/system/vsound.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2021-01-14 20:10:28 JST; 41min ago
Main PID: 221 (aoe)
Tasks: 1 (limit: 2150)
CGroup: /system.slice/vsound.service
└─221 /usr/bin/aoe -i eth0 -d DC:A6:32:0E:39:10
Jan 14 20:10:28 archlinux64 systemd[1]: Starting Audio over Ether Virtual Sound Card...
Jan 14 20:10:28 archlinux64 systemd[1]: Started Audio over Ether Virtual Sound Card.
Jan 14 20:10:28 archlinux64 aoe[221]: 628.936806 main [ 928] 0| HWaddr dc:a6:32:10:c2:4e
Jan 14 20:45:00 archlinux64 aoe[221]: 700.282119 main [1005] 0| SND_PCM_STATE
REPARED(2) S32_LE 44100 2, send *Neighbor Discovery*
Jan 14 20:45:00 archlinux64 aoe[221]: 700.382179 main [1005] 0| SND_PCM_STATE
Jan 14 20:45:00 archlinux64 aoe[221]: 700.419077 unbox [ 597] 49204| recv *SYN* CLOSED->CONNECTED chunk_bytes:1176, send *ACK*
Bác xem giúp log này có OK không?
