Custom firmware Q10 Pro, Q5 Pro, Q30.
haovh_85
Update CFW 2.1.1 cho Q10 Pro và Q5 Pro. AE download ở trang đầu nhé! Changelog như trên update thêm google app, fix lỗi chạy ngon Myk+...
AE có thể update từ Settings. Nhưng khuyến cáo chọt lỗ reset cho ổn định.
haovh_85
Hôm nay mình mình sẽ build lại các bản CFW và ATV 2.1.1 cho Q10 Pro, Q5 Pro và Q30. AE download về có thể update từ settings nhé!
* Build mới fix một số lỗi còn tồn tại.
* Cập nhật file host mới nhất để chặn quảng cáo.
* Cập nhật google app.
Download ở trang 1 ae nhé!
vinagoh
Có gì mới hơn so với bản 2.0.8 kg Bác?? Thanks. :D
haovh_85
Changelog:
1. From settings, user can select: Power-on to boot or power-on to standby
2. New Happycast App version
3. Solved the problem that when watching live TV, to press the power-off button probably cause the box dead
4. Solved the problem that if there is a blank space,the SMB share path cannot be mounted
5. Solved the problem that SMB cannot be accessed to the shared space of Win10 system
6. Solved the problem that SMB cannot be accessed to the shared file, of which title includes special characters
7. Solved the problem that the LED display probably does not work after the upgrade.
8. Solved the problem that adjusting the volume during Youtube playback caused the system to hang
9. Optimized the video player to solve the problem that some subtitles are flashing
10. Optimized the video player to solve the problem of not being able to switch proportions when playing video
11. Optimized system stability and solved the problem that some machines occasionally fail to boot
12. Optimized the HDMI compatibility, and solved the problem that when exiting the video playback on some amplifiers, the TV screen is flashing
13. Optimized NFS compatibility, solved the problem that NFS shared files cannot be played caused by the too deep path
filmHD
Bac haovh_85 lam sao cho sctv online chay full man hinh tren q10 pro ko?
Bạn vào settings --> Video Output --> Maintain aspect ratio chọn chế độ Extrude . Lưu ý nếu chọn chế độ này thì sẽ full màn hình khi xem sctv nhưng khi xem phim trong kodi thì nó sẽ xãy ra chuyện full màn hình nếu như bạn xem bản nén . Nếu gặp hiện tượng này thì bạn vào chuyển chế độ Extrude sang chế độ Add black side . :)
si lam
Minh da lam theo huong dan cua ban nhung xem sctv online van ko full man hinh dc? Minh dang dung ban CFW 2.1.1 cua futeko. Ban co cach nao khac ko?
hoanganhduc78
Mình chưa update q10 bao giờ, cho mình hỏi mình đang dùng 2.0.9 mình lên bản 2.1.1 luôn được không? Có 2 file theo bạn mình lên dùng file nào? Nếu update kiểu reset (chọc lỗ) sau khi update xong thì các app mình phải cài lại đúng không? Kodi admin tích sẵn trong bản 2.1.1 rồi à? Thanks mọi người
si lam
Ban nao biet xin huong dan cai man hinh dong cho ban fw goc 2.1.1 voi. Xin cam on
hoanganhduc78
Tình hình là update thành công, nhưng bị lỗi bị treo không bật tắt được, chỉ có cách tắt nguồn
hiep1750
Đã bạn nào dùng Google TV 2.1.1 Android 7.0 Yêu cầu cập nhật từ 2.0.4 trở lên, Chơi Bluray Full Menu, Duyệt Poster chưa vậy? Có gì hay ko? khai thác như thế nào? so với cái này FW Stock 2.1.1 Android 7.0 Yêu cầu cập nhật từ 2.0.4 trở lên, Chơi Bluray Full Menu, Duyệt Poster, MyK+ thì sao? Nên dùng cái nào? thanks
