Mede8erViet
Cập nhật thông tin của firmware với các lỗi được fix, các tính năng mới được thêm vào cho Mede8er MED1000X3D tại đây để anh em tham khảo sử dụng
Download - V1.03 - 29Sept 2012-BETA
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/MED100X3D_V1.0.3_29September_BETA/install.img
MD5 - D735AC7F56A6FA970B070C2478D1D48F
Changelog
1) New functionality - match embedded BD / MKV Audio track and Subtitle to OSD Language - Setup Option MISC page
Note: for MKV the audio track and sub language flag info needs to be set.
2) Changed screensaver to default screensaver when in Video Pause and Music Jukebox
3) New Diagnostic functionality - Display NFS mount info - Mount a NFS share and press the 'F1' button and NFS connection details will be displayed ie vers=3,rsize=32768,wsize=32768,proto=udp,port=65535,timeo=7,retrans=3,addr=192.168.10.20
4) Improved BD Playlist functionality for 3DBDISO
5) Copy to USB Drive / Loosing Favourites Links/ Watched Indicator - Fixed - New Functionality - NTFS Check - Open Devices Page and press the 'F1' button then select a drive and X3 will perform a - NTFS check and reset the Dirty Bit flag and check the file system. Suggest to use this functionality if you experience any write to HDD / USB problems.
6) Popping sound when selecting 'menu' in Video Play - Fixed
7) 'Audio Menu' changed to auto remove after 5 sec
Known Issues -
1) MVC - MTS files not working - will fix in next BETA
2) X3 freeze when streaming MKV via NFS on wired Gbit Network - Will fix this in next BETA
Workaround -
a) Connect x3 via 10/100 port
b) Try Firmware version V1.03 - 26Aug 2012
c) Use Samba
V1.03 - 21Sept 2012-BETA
Changelog
1) New Functionality - NFS mount Auto Scan
X3 will Scan the NFS servers on the same IP segment, on boot up. Additionally you can perform a manual NFS scan with a new option called 'Probe' in the NFS menu.
2) New function - AAC/MP3 Force decode - If set to 'on' AAC/MP3 will be decoded to PCM
3) Fixed embedded Italic tag showing in MKV subs
4) Improved performance when decoding High Bittrate mkv with HD Audio
Known Issues- MVC - MTS files not working
V1.03 - 18Sept 2012-BETA
Changelog
1) Fixed 'Autoplay' Functionality
2) Fixed Subtitle tags <i> ie now hidden - EDIT - Embedded mkv not fixed
3) Fixed - Respect Default Audio flag in MKV files
4) Fixed - Network Login Screen
5) BD Playlist
a) Improved the graphic presentation
b) Fixed X3 freeze after using Playlist function
c) Fixed Chapter support within a Playlist
d) Fixed Left . Right Nav Jog - GOTO within a Playlist
V1.03 - 12Sept 2012-BETA
Changelog
1) Removed NTFSFIX as introduced in V1.0.3-30Aug as it causes problems with 3TB drives
2) Fixed Internet connection on wire Network
2) Corrected the Audio Display when using 'Info' button during video play
3) Fixed HDD Spin Down time adjust
4) Added Auto fps for 50/60/59.940 fps
5) Corrected display in 3D to 23.976
6) Changed Default Audio setting after install to 'HDMI Auto'
7) New functionality - BD Audio will now play in preference of supported quality ie HD Audio --- Normal Core Dolby/DTS/ --- PCM
Cool Fixed Croation Language GUI
9) Alpha Functionality - BD Playlist - Press Menu Button during BD Play and Select 'Playlist' - should be completed next week
Known Critical Bugs
26Aug - Copy from internal HDD to USB not always working - investigating this
V1.03 - 30Aug 2012
Changelog
1) Fixes hostname issue that was introduced by 29 aug version
2) Added EDID read and save
Known Critical Bugs
Internet not working ie YouTube, Browser, Internet Radio etc
Download - V1.03 - 29Aug 2012
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/MED100X3D_V1.0.3_29August_BETA.zip
V1.03 - 29Aug 2012
Changelog
1) Samba stream issue with High Bitrate MKV inc DTSMA fixed
Known Critical Bugs
Download - V1.03 - 27Aug 2012
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/MED100X3D_V1.0.3_27August_BETA.zip
V1.03 - 27Aug 2012
Changelog MDS -- AD0DFC9B85815DD78F6829339CD20314
1) Hopefully fixed Lip Sync 'on' issue on Pioneer amps -- Needs testing
Known Critical Bugs
Download V1.0.3 22 August BETA 2012
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/x3_V1.0.3_Aug22_BETA.rar
V1.03 - 22Aug 2012
b]Changelog
1) Fixed Auto Frame Rate 'Auto'TV Sys changing to NTSC when exiting a video
2) Fixed 24hz 3DBDISO functionality
Known Critical Bugs
Download V1.0.3 18 August BETA 2012
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/MED100X3D_V1.0.3_18August_BETA.zip
V1.03 - 18Aug 2012
b]Changelog[/b] MDS - 1E9F67058495041C861C27A4E021B4A6
1) Fixed Auto Frame Rate functionality - Needs testing - Enable 'Auto Frame Rate' in Setup Menu to test
2) Fixed very slow start of some video files
3) Fixed Pause Icon not showing MKV files
4) Added 24hz to 'TV Sys' Display -- If X3 Outputting at 24hz and you press TV Sys it will now display 24hz.
Download V1.0.3 15 August BETA 2012
http://www.mede8er.org/beta/Firmwares_Beta/MED1000X3D/MED100X3D_V1.0.3_15August_BETA.zip
V1.0.3 -- 15 August 2012 MD5- 0964989FF69EF18DEA8E1049636FF4E0
Changelog
1) Youtube Crash - VEVO videos - Fixed
2) BT Downloader - Fixed
3) Core DTS / Dolby 5.1 X3 will not pass Core DTS 5.1 / Dolby 5.1 from DTSMA / Dolby True HD source on SPDIF - Fixed
4) Auto Frame Rate BDMV/BDISO / 3DBDISO - Fixed
5) Polish -- Localization update
6) AVI with Subtile 'Pause' issue - Fixed
7) Pause Video / after screensaver subtitles missing - Fixed
Cool Return from YouTUBE to Favourites on Home Page - Fixed
9) 'F4' *Favourites Function not working - Fixed
10 Added support for txt subs
V1.0.3 -- 10 August BETA 2012 MD5- 3A87A489E861147DD9368874F44F1761
Changelog
1) Added CEC on/off in Setup Menu You can read more about CEC options:- CEC - AfterDawn: Glossary of technology terms & acronyms
2) Fixed BD Menu on/off 'F3' button (Fixed vs previous internal Beta v1.03 - 7Aug 2012)
3) Fixed Return after launching a Fav Link - Now it Returns back to Favourites (Fixed vs previous internal Beta v1.03 - 7Aug 2012)
4) New Aplha functionality BD Playlist select on Menu button options when playing BD structure.
V1.03 - 7Aug 2012
Changelog
1) Fixed cold boot up freeze if with large size internal HDD and PCIE WIFi
2) Updated BD Patches to fix BDMV / BDISO problems
3) * Added 'Auto Frame Rate' Setup Menu
Auto frame rate is designed to output the correct frame rate for NTSC or Pal content
If enabled
25fps ---> output changes to 50hz
29.97fps ---> output changes to 60hz (59.94)
On exiting the video the TV Sys out will change back to the 'Default' as selected by the user in the Setup Menu.
4) Updated Thai Localization text
5) Added Polish Localization Text
V1.0.2 -- 24 July2012
Changelog
1. Fixed Secure Samba Login
2) Fixed 'WORKGROUP' name change - must reboot after making this change
4) Added support for USB Keyboard Text input in Web Browser and Jukebox Search
5) Fixed folder.jpg showing about.jpg when using VIDEO_TS structure in Movie Jukebox
6) Fixed Info bar when using mp4 files on DNLA DMR
7) Fixed showing default embedded subs MKV files
Cool Fixed Hebrew text mirror
9) Auto Play 3D BDISO in 3D (BD Menu must be 'off')
10) Added toggle function on 'F3' button for BD Menu
Download Firmware
V1.0.2 --24July2012
http://www.mede8er.org/beta/Firmware_Final/MED1000X3D/x3_V1.0.2_Jul24.rar
USER MANUALS
MED1000X3D
http://www.mede8er.org/artwork/temp/Mede8er_med1000x3D_user_rev2_22July_corelX6.pdf
AFTER THE UPDATE WE SUGGEST YOU UNPLUG AND REBOOT THE X3 AND THEN CONTINUE
If you installing a new Hard Drive then it should be formatted in the X3 for correct operation. After the format the Hard Drive should be shown as HDD: in the Media Library. (Not the Devices Page) If it not shown as HDD then you must format the Hard Drive a second time. Existing Pre Formatted Hard Drives or NTFS only Hard Drives may show as (C)
Emergency Procedure
Download the latest Mede8er Firmware from Mede8er Forum - Index. UnZIP or UnRAR or join with HJ Split and will find one file named install.img. Copy this file to the root directory of a Flash Drive. Plug the flash drive into the Mede8er. Unplug the power to the X2. Plug the power jack back in and hold the ON/OFF button on the Mede8er (not the remote) down for 15sec and then release. After the firmware has been checked (+-5-10sec) it will start to update. You will see the update progress on your TV. Do not remove power during the Firmware Update procedure .
PASSWORD PROTECT NETWORK SHARES -- NAS SETUP
Use the My_Shortcuts method as shown in this demo Mede8er - X2 Add Shortcut Tutorial
PUBLIC SHARES -- PC / NAS
Username: Guest
Password: Guest
IP: xxx.xxx.xx.xx
Mede8er1
