Bộ CoreAVC H264 Video Codec Pro v2.0.0
rongruby
Mình lên mạng search tùm lum trang cuối cùng cũng tìm được 1 bộ CoreAVC H264 Video Codec bản mới nhất. Nay mún chia sẻ cho bạn nào có nhu cầu sử dụng bộ này để giải mã thêm cho việc xem HD.
Thông số kỹ thuật:
CoreAVC H.264 Video Codec Pro v2.0.0
Worlds Fastest High Definition H.264 Video Software Decoder
Released: December 21, 2009
he latest and greatest version of this much requested codec.
CoreCodec CoreAVC 2.0 for Windows is a complete solution for playing high quality HD H.264 videos on your Windows based computer. CoreAVC comes (in part) from the creators of the Matroska MKV Container (.mkv), So you know it's gotta be good!
The efficiency of CoreAVC in 'software' is often compared to be faster than other solutions that try to rely on 'hardware' to increase playback performance of H.264 video.
CoreAVC 2.0 fully supports GPU hardware acceleration with NVIDIA CUDA Technology, and works with other compatible NVIDIA Platforms like ION running on Windows XP, Vista, or 7.
Is fast becoming the industry standard for high quality H.264 playback. For the highend video zealots CoreAVC Professional Edition even supports SMP processors, allowing for even fast multitasking while playing back high-definition CoreAVC H.264 video.
Key Features:
* New! Supports Windows 7
* New! 32/64 bit Support
* New! NVIDIA CUDA GPU support
* Supports up to 16 CPU Cores
* QuadHD Resolution Support
* Uses Directshow for MKV
* Includes the Haali Media Splitter
* Full Interlaced support
Development SDK
The CoreAVC SDK is one of the most advanced yet simple SDK's for developers to easily add H.264 support within their products. The SDK features:
* Directshow/GStreamer support
* Supports all modern OS's
* ARM/MIPS/PPC/32/64bit CPU's
* NVIDIA CUDA GPU support
* ARM Cortex NEON A8 support
* RMI MAE GPU Support
* Library/Source code options
Haali Media Splitter (20091112)
- ADD: Official 64bit support
- ADD: Official support for Windows 7
- ADD: Custom fourcc option for windows 7
- ADD: Silent install flags for each install option
- CHG: Disabled explorer thumbnail support (off by default)
Và cuối cùng là link down cho mọi người.
CoreAVC H264 Video Codec Pro v2.0.0.rar
Tks bạn tngoctu đã chỉ mình, vì mình mới tập tành chơi HD nên chưa bík rõ lắm :D
Mình xin cập nhật thêm bản 2.5.1.0 vừa tìm được
http://up.4share.vn/f/340502010503010c/CoreAVC%202.5.1%20Professional%20Edition.rar.file
- FIX: Windows Media Player seeking with MKV
- FIX: MediaPortal crashing
- FIX: Graphstudio crashing
Về phần còng thì các bạn có thể search trên topic ngay trên. Mình cũng xin đưa link dẫn vào lun cho tiện.
http://www.hdvietnam.com/diendan/4-software-ky-thuat-phan-mem/106-huong-dan-config-toi-uu-mpc-coreavc-ffdshow-ac3filter-de-xem-phim-hd.html
Chúc các bạn thành công.
Doatphach
Ðề: Bộ CoreAVC H264 Video Codec Pro v2.0.0
Bộ 2.5 xem DXVA ngon lành ko bị vỡ hình như bản 2.0.1
rongruby
Vâng cám ơn 2 bác đã chỉ giáo. Có gì thiếu sót xin chỉ giáo thêm. Mục đích là mún chia sẻ thêm cho anh em thôi ạ. :D
Em có 1 bộ decoder của cyberlink 10.0 (chỉ bộ giải mã thôi chứ ko phải cả 1 bộ cài Cyberlink PowerDVD 10) ko bík có nên share cho mọi người ko. Xin ý kiến các bác lun :D
Doatphach
Chỉ lấy file .ax phải ko. trên dd cũng có rồi nhưng bạn cứ đưa lên . Càng nhiều lựa chọn chứ sao
hai1506
bạn có bộ codec mới nhất của cyberlink và coreAVC k cho mình xin đi
codec của cyberlink và codec của coreAVC, cái nào chạy ngon hơn mấy bác vậy, xin chỉ giáo
anhkothikchoi
hay
mình chỉnh theo các thông số trên.xem hd thi ok,nhung xem 1 so file avi hay mpeg khác bị hiện tượng sau:
có 1 layer phủ toàn toàn man hình làm biến thành trắng đen hết,van play binh thuơng,co tiếng, chạy mượt ko giật. có ai bị thế này chưa?xin chỉ giúp
anhkothikchoi
hay
hai1506
ngoài 2 bộ codec để chạy HD này, bác nào còn biết bộ codec nào chạy HD ngon nữa k, mình mới bắt đầu chơi HD nè, lạc hậu quá, các bác xin giúp đỡ
kiatisak
Mình có 2 bộ code của PowerDVD12 và CoreAVC 3.0.1 Professional Edition nè:
PowerDVD12:
CoreAVC 3.0.1 Professional Edition:
hai1506
PowerDVD12:
p
rất cám ơn bạn vì tinh thần chia sẻ cộng đồng
nhưng code của cyberlink DVD 12 không download về được, hình như là file k tồn tại, bạn có thể up lên mediafire dc k
hai1506
code coreAVC version 3.0.1 hình như bị phát hiện rồi
mình khuyên nên dung 3.0.0 cho nó lành, k bị lỗi các bác
kiatisak
Mình ko có acc mediafire, để mình up lại.
Mình đã up lại rồi đó, cập nhật ở trên.
Bạn bị như thế nào mà bị lỗi, cần mình chup hình xài bình thường lên ko, mình vẫn đang xài nè.
hai1506
mình down về codec PowerDVD 12 rồi, mình tưởng là file cài đặt chứ, cái này mình k biết dùng rồi, bạn có thể chỉ cách dùng dc k, thank
codec PowerDVD 12 bạn đưa là chỉ cần cài đặt power DVD 12 rồi lấy ra thôi, mình đang dung win 8, add theo mấy cách trên mạng k dc. Bạn có file cài codec của PowerDVD 12 k, file cài thì ngon lành
bạn có bộ codec của Nvidia --- PureVideo Platinum k bạn, share dc k
kiatisak
Bộ code PowerDVD 12 đâu có bộ cài, bạn cài nguyên PowerDVD 12 rồi lấy phần code Video này để xài thôi, mình xài trên lap cài Windows 8 vẫn chạy bình thường nè.
Bạn vào MPC-HC nhưng phải là bản 32 bit, vì bộ code PDVD ko xài được cho bản MPC-HC 64 bit
Bạn vào Option -> External Filters -> Add Filter -> Browse -> chỉ đến đường dẫn chứa code PDVD12, chọn file Claud.ax -> OK -> chọn nó là Prefer.
hai1506
bạn ktra lại dung dc k, trong codec bạn đưa k có file Claud.ax
mình hiểu rồi, nhưng mình thích xài WMP hơn, bạn biết cách nào add codec cho WMP k
hay bạn có bản cài đặt codec cũ hơn của thằng cyberlink PowerDVD cũng dc, bản 11, hay bản 10
kiatisak
Mình ko có mấy bộ code đó và ko xài VMP.
CoreAVC ko tương thích với Windows 8 nên mình mới xài bộ code PDVD. Hôm nay đi làm ko đem theo lap để chiều về mình chụp xài trên Windows 8 cho bạn xem.
kiatisak
Bạn vào Option -> External Filters -> Add Filter -> Browse -> chỉ đến đường dẫn chứa code PDVD12, chọn file CLCvd.ax (sáng mới ngủ dậy nên nhìn lộn tên file)-> OK -> chọn nó là Prefer.
kiatisak
Mình chỉ tìm được bản này NVIDIA PureVideo Decoder Platinum 1.02-223, mình cài thử thành công.
