WD TV™ HD Media Player
Hôm nay, J lang thang thấy được pé này. Ko biết bên bác HoangTuan có chưa (hàng WD mà, thấy bác bán toàn hàng WD
File Formats Supported
Music - MP3, WMA, OGG, WAV/PCM/LPCM, AAC, FLAC, Dolby Digital, AIF/AIFF, MKA
Photo - JPEG, GIF, TIF/TIFF, BMP, PNG
Video -MPEG1/2/4, WMV9, AVI (MPEG4, Xvid, AVC), H.264, MKV, MOV (MPEG4, H.264)
Playlist - PLS, M3U, WPL
Subtitle -SRT (UTF-8) - Không biết chơi được Việt Sub nhà mình ko?
Note:
- MPEG2/4, H.264, and WMV9 supports up to 1920x1080p 24fps, 1920x1080i 30fps, 1280x720p 60fps resolution
- An audio receiver is required for surround sound output. AAC/Dolby Digital decodes in 2 channel output only
- JPEG does not support CMYK or loss less.
- BMP supports uncompressed format only.
- TIF/TIFF supports single layer only.
File Formats Not Supported
Does not support protected premium content such as movies or music from the iTunes® Store, Cinema Now, Movielink®, Amazon Unbox™, and Vongo®
External Drive Formats Supported
FAT32, NTFS, HFS+ (no journaling)
Performance Specifications
Serial Transfer Rate
USB 2.0
Serial Bus Transfer Rate (USB 2.0) 480 Mbits/s (Max)
Physical Specifications
Capacity N/A
Interface HDMI, Composite A/V, USB 2.0
Physical Dimensions
English
Height 1.57 Inches (Max)
Length 3.94 Inches (Max)
Width 4.94 Inches (Max)
Weight 0.67 Pounds
Metric
Height 40 mm (Max)
Length 100 mm (Max)
Width 125.5 mm (Max)
Weight 303 g
Environmental Specifications
Temperature (English)
Operating 41° F to 95° F
Non-operating -40° F to 149° F
Temperature (Metric)
Operating 5° C to 35° C
Non-operating -40° C to 65° C
Electrical Specifications
Current Requirements
Power Dissipation
AC Input Voltage 100-240 VAC
AC Input Frequency 50-60 Hz
Nguồn WDC
Không biết có bác nào biết em pé này ko? Và giá em tham khảo tại một số shop của ẻm từ
$100 - $150
