@sadays
I have checked Tidal Connect on Pi 4
My account: TIDAL HiFi Plus
edit file: /root/tidal-connect/configure.sh
--log-level 4
Play Tidal Connect: Rachmaninoff: Piano Concerto No. 2 in C Minor, Op. 18 - I. Moderato
Check with the command:
docker logs tidal-connect
or list id docker:
docker ps
command:
docker logs id
I see the logs:
Decoder got 63420160 total frames for AudioMetadata [
channels: 2 bitsPerSample: 24 sampleRate: 96000 ]
I play Tidal Connect from my laptop, the connection is always stable, and the quality has no issues. My phone is an older Android device, so I can't install Tidal to test playing from the phone. I don't understand why you're encountering a 48kHz issue.
is my log
Card number: 0
ALSA lib pcm_dsnoop.c:618
snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm.c:2495
snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2495
snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2495
snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2495
snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2495
ALSA lib pcm.c:2495
snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2495
ALSA lib pcm.c:2495
snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm.c:2495
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Device info for the card number: Combo384 Amanero: USB Audio (hw:0,0)
FRIENDLY_NAME=TIDAL connect
MODEL_NAME=Audio Streamer
MQA_CODEC=false
MQA_PASSTHROUGH=false
CARD_NAME=
CARD_INDEX=
BEFORE
defaults.pcm.card 0
defaults.ctl.card 0
Specified CARD_NAME=[Combo384 Amanero: USB Audio (hw:0,0)]
defaults.pcm.card 0
defaults.ctl.card 0
PLAYBACK_DEVICE=[default]
Starting Speaker Application in Background (TMUX)
Sleeping for a while (3 seconds)...
Starting TIDAL Connect ...
STARTING TidalConnect services, version: 1.1.3
ALSA lib pcm.c:2495
ALSA lib pcm.c:2495
ALSA lib pcm.c:2495
ALSA lib pcm.c:2495
ALSA lib pcm.c:2495
ALSA lib pcm.c:2495
ALSA lib pcm.c:2495
ALSA lib pcm.c:2495
ALSA lib pcm.c:2495
[2023-10-28 10:07:09.691] [tisoc] [critical] [DeviceInfo.cpp:56] ioctl error. ret=-1, errno="No such device"
[2023-10-28 10:07:09.692] [tisoc] [critical] [DeviceInfo.cpp:57] [ASSERT] generateDeviceId(0)
STARTED TidalConnect services.
[2023-10-28 10:07:38.251] [tisoc] [warning] [PlaybackControllerImpl.cpp:472] Illegal state:1
