Symphonic-mpd là một lựa chọn tuyệt vời cho anh em audio.Có roon, uPnP nữa thì ngon
Symphonic-MPD provides latency under 2µs on a Raspberry Pi. This is 2,500 times lessthan the 5ms claimed by Audiophile Linux, a typical Linux distribution for audiophiles which features a low latency real time kernel.
Characteristics of symphonic-mpd
- Real-Time Kernel (Xenomai 3.0. 7)
- Proprietary Xenomai driver and playback software specialized for I₂S output has been developed
- Custom patching to kernel, MPD, AirPlay, Spotify Connect, ALSA-lib, and other libraries for high fidelity playback
- Optimized builds for a fast and compact system
- Optimized real-time priority and CPU execution
- mpd, AirPlay, Exclusive Spotify Connect (Automate unnecessary process stops and NAS unmounts)
- Reduction of noise and stabilization of voltage by stopping HDMI, Wi-Fi, Bluetooth services, and USB bus power, underclocking of CPU/GPU, and turning off LEDs
- Improved PLL accuracy improves the sound quality of I2S HAT when running in slave mode. When using I2S HAT that runs in master mode, PLL setting is canceled by replacing dt-blob.bin. This reduces CPU load.
- Reduction of operating system jitter by suppressing kernel thread interrupts and tuning kernel parameters
- ALSA buffer tuning to match the playback sampling rate
- Auto-Tuning of NAS mount settings to optimize throughput (It takes about 30 seconds to measure throughput.)
- Ultra-lightweight, low load web server YMPD as a Web UI
- UNIX domain socket communication between MPD and YMPD rather than the typical use of TCP port 6600
- Online version updating
Sao của em Spotify không chạy anh.![]()
Chạy con digione ở chế độ master nghe spotify hay quá các bác, chắc nó sử dụng hiêu quả 2 con clock 957.
Hết hạn roon cũng có cái thay rồi, mai ké nas bác @linh0893 xem thử sao![]()
Bác vào spotify nhập username và pass, sau đó khỏi động lại mới nhậnSao của em Spotify không chạy anh.
Trong menu soundcard chọn digione, sau đó khởi động lại bácBác chọn dac hat tên gì ah, chỉ mình cách thêm vào như nào với
Anh tham khảo:Em gú gồ mãi mà vẫn không thấy bài của 1 Bác hướng dẫn giảm xung cho pi3 ( do em mới cài lại os Rune ). Bác nào còn lưu link share em với. Thanks các Bác.
Chính xác bác, khi đang play nhạc nó ngắt hếtTheo bác cài Digione trên Pi4 2GB cấp nguồn IFI ipower cho pi + digione nguồn ngoài (lởm) >> DAC Topping DX7 pro nghe qua Spotify thấy hay bất ngờ ạ.
Qua đó mới thấy sức mạnh của phần mềm.
PS: hiện hay bị lỗi mất kết nối khi play spotify? Hay nó chỉ ưu tiên kết nối nhạc?
PS1: smdp tối ưu kết nối "dã man", đang nghe nhạc không có vọc vạch chi hết. NGẮT KẾT NỐI luôn.
nghỉ chơi nhạc vọc bình thường.![]()
Em dùng Winscp vào để edit. Mới file đầu tiên là báo thế này rồi. Nhờ các bác chỉ giúp![]()
cảm ỏn bác. bác giải thích ho em đoạn này với ah. em ngồi mò cả buổi chẳng được. em đang thử bản smp 0.9 cho pi3Bác SSH vào, bấm vào biểu tượng như hình
Gõ user, pass rồi pate dòng dưới vào Enter rồi quay lại edit
sudo chmod -R 777 /lib/systemd/system/mpd.socket
sudo chmod -R 777 dòng này để cấp quyền ghi xóa file, folder
Create upmpdcli.conf.
# (Reference) /etc/upmpdcli.conf setting
#mpdhost = 127.0.0.1 (default)
#mpdport = 6600 (default)
friendlyname = SymphonicMPD (Any renderer name)
checkcontentformat = 0
openhome = 1
lumincompat = 1
ohproductroom = SymphonicMPD
ohmetapersist = 1
logfilename=/var/log/upmpdcli.log (Specifies that it should be logged)
loglevel = 3 (It won't start if you get a level 1 error)
4. Add to mpd.conf lines below.
# Setting of /etc/mpd.conf (Added the following)
input {
plugin "curl"
# proxy "127.0.0.1:8123" (No polipo in use, comment in)
5. Create a user named "upmpdcli" as it doesn't work as root.
useradd upmpdcli
touch /var/cache/upmpdcli
Mount NAS mãi chưa được, ssh vào thì assess denied! pi/raspberry.Chính xác bác, khi đang play nhạc nó ngắt hết![]()
Cảm ơn bác. để em làm thử xem, không được chắc nhờ bác làm giúp. Hi hiBác làm như sau:
Create upmpdcli.conf =>
1. suso nano /etc/upmpdcli.conf
2. Copy code này pate vào sau đó nhận Ctrl+X, Y, Enter
3. sudo nano /etc/mpd.conf
Copy code mục 4 pate vào sau đó nhận Ctrl+X, Y, Enter
4. Create a user named "upmpdcli" as it doesn't work as root. = Gõ 2 dòng
sudo useradd upmpdcli
sudo touch /var/cache/upmpdcli
Bản 1.0.x anh dùng root / raspberry
Các bản cũ là pi / raspberry
PS2: mount NAS chưa ngon, tâm tịt, nghe tạm Spotify, coi như là Network Adapter.
