VD2000
Có Bác nào cài đặt màn hình
Waveshare Spotspear 3.5" Touch Screen
cho Pi3 chạy Rune thành công rồi thì share file .img giúp em với. Em setup hoài không được hichic.
Link hướng dẫn vậy mà ko thành công :(
Tuong Ban da lam duoc roi vi khong thay ban len tieng nua neu chua lam minh co the chi dan duoc, va da lam tren ban Rune moi 2017 luon.
VD
VD2000
Day la cac buoc minh da lam va ghi note lai :
RuneAudio beta 20170229 + 3.5" LCD
# copy file waveshare35a.dtb to folder Overlays of rune, and rename *.dtb to *.dtbo
# Install video driver packages xf86
wget http://tardis.tiny-vps.com/aarm/pac...o-fbturbo-git-199.f9a6ed7-1-armv7h.pkg.tar.xz
tar -xvpwf xf86-video-fbturbo-git/xf86-video-fbturbo-git-199.f9a6ed7-1-armv7h.pkg.tar.xz -C / --exclude .PKGINFO --exclude .INSTALL
# Add follow those to config.txt files
nano /boot/config.txt
start_x
gpu_mem=128
core_freq=250
sdram_freq=400
over_voltage=0
dtparam=spi=on
dtoverlay=waveshare35a-overlay.dtbo
dtoverlay=ads7846,cs=1,penirq=17,penirq_pull=2,speed=1000000,keep_vref_on=1,swapxy=1,pmax=255,xohms=60,xmin=200,xmax=3900,ymin=200,ymax=3900
dtparam=i2c_arm=on
dtoverlay=w1-gpio-pullup,gpiopin=4,extpullup=1
# Add those line at the end of the line in cmdline.txt file
nano /boot/cmdline.txt
fbcon=map:10 fbcon=font:proFont6x11 logo.nologo
# Create the file /etc/X11/xorg.conf.d/99-calibration.conf and insert the following
nano /etc/X11/xorg.conf.d/99-calibration.conf
Section "InputClass"
Identifier "calibration"
MatchProduct "ADS7846 Touchscreen"
Option "Calibration" "3932 300 294 3801"
Option "SwapAxes" "1"
EndSection
# In /etc/X11/xorg.conf.d/99-fbturbo.conf, change to :
nano /etc/X11/xorg.conf.d/99-fbturbo.conf
Option "fbdev" "/dev/fb0"
to
Option "fbdev" "/dev/fb1"
# Add the following to /etc/modules-load.d/raspberrypi.conf:
nano /etc/modules-load.d/raspberrypi.conf
i2c-bcm2708
i2c-dev
flexfb width=320 height=480 regwidth=16 init=-1,0xb0,0x0,-1,0x11,-2,250,-1,0x3A,0x55,-1,0xC2,0x44,-1,0xC5,0x00,0x00,0x00,0x00,-1,0xE0,0x0F,0x1F,0x1C,0x0C,0x0F,0x08,0x48,0x98,0x37,0x0A,0x13,0x04,0x11,0x0D,0x00,-1,0xE1,0x0F,0x32,0x2E,0x0B,0x0D,0x05,0x47,0x75,0x37,0x06,0x10,0x03,0x24,0x20,0x00,-1,0xE2,0x0F,0x32,0x2E,0x0B,0x0D,0x05,0x47,0x75,0x37,0x06,0x10,0x03,0x24,0x20,0x00,-1,0x36,0x28,-1,0x11,-1,0x29,-3
fbtft_device debug=3 rotate=90 name=flexfb speed=16000000 gpios=reset:25,dc:24
ads7846_device model=7846 cs=1 gpio_pendown=17 keep_vref_on=1 swap_xy=1 pressure_max=255 x_plate_ohms=60 x_min=200 x_max=3900 y_min=200 y_max=3900
#### Option ####
# check if local browser ( midori) is enable = " redis-cli get local_browser "
If not do this = "redis-cli set local_browser 1 "
# Rotate screen
dtoverlay=waveshare35a-overlay.dtbo,rotate=270
# Zoom in screen
nano /root/.config/midori/config
changes zoom-level=0.7 to zoom-level=0.5
nqn_vnn
Mình đã copy file waveshare35a.dtb và đổi tên, đã chạy lệnh wget ...... Nhưng chạy lệnh "tar -xvpwf...." thì bị lỗi như hình\
Bác xem hộ mình là lỗi gì với.
Con này giống thiết kế con F-1 mà bác, chỉ có nhiều cổng ra hơn thôi và chọn clock khác (thông số thấp hơn và rẻ hơn) thôi. Đúng là Tàu, chỉ một thoáng thôi đã có bọn khác làm giống hệt ý tưởng rồi :D
Hình như con nhái F1 này phải cấp nguồn 5v nó mới chạy phải ko bác Trung .
Nguồn 5v USB cấp cho Chip Xmos còn nguồn riêng 5v cấp cho mạch cách ly . :rolleyes:
trung224
Đúng rồi bác ạ. Thật ra như con nhái này mới chuẩn còn con F1 là isoalation kiểu "giả cầy", vì như con F1 chỉ cách li điện trên phần data còn phần cấp điện và ground vẫn dùng chung chả cách ly gì.
TTViet
Bên vnav.vn có bác Hùng chủ Shop Audio Master đang thiết kế Music Server dựa trên nền Linux (Raspberry Pi), giao tiếp Usb Xmos và phần mềm điều khiển Runaudio. Thấy cũng có nhiều ý kiến đánh giá tốt. Xin cộng đồng chơi Raspberry Pi for Audio bên này cho vài ý kiến đánh giá và nhận xét khách quan:
- Cấu hình công bố:
- Link: http://vnav.vn/threads/masteraudio-music-server-9028m-san-pham-den-voi-moi-nha.33130/page-6
Đính kèm
    815.9 KB · Xem: 2
TTViet
Xin lỗi bác, tôi dùng từ sai. Thấy thú vị thì mang lên đây hỏi ae thôi, kẻo lại bị lỗi sai văn bản giống bên Văn hóa thì chết.
trung224
Em nghĩ nếu bác ấy làm ra một sản phẩm mà không phải rebranding (mua một sản phẩm khác về đổi vỏ) thì hoàn toàn gọi là "thiết kế" được.
Quay trở lại sản phẩm, thông tin rất mù mờ cũng như ko có ảnh bên trong để biết thật sự lòng mề có những cái gì nên thât sự rất khó đánh giá. Các thông số hardware specification hay connectivity là thông số của Raspberry Pi. Các thông số main features (như THD,SNR, dynamic response) không phải là của thiết bị mà chỉ là của con chip ES9028 (của thiết bị thông số sẽ thấp hơn), dù thông số đó chẳng liên quan lắm đến chất lượng thực sự của sản phẩm. Nói chung nó như một cái "hộp đen", ko có bất kì thông tin gì. Muốn đánh giá phải chuột bạch hoặc bác nào đã sở hữu mở ra chụp cái ảnh lên thì mới có cái để nhận xét.
lmcuong4u
Xin lỗi các bác nhiều trang quá em k đọc hết nổi..
Em muốn hỏi nếu mua board BOSS DAC thì về chỉ cần cắm trực tiếp lên pi3 là chạy đúng k ạ?
VD2000
trong hinh thi ban da save files thanh ( xf86-video-fbturbo-git-199.f9a6ed7-1-armv7h.pkg.tar.xz.1)
nhung khi ban tar extract no thi ban da danh sai ( xf86-video-fbturbo-git-199.f9a6ed7-1-armv7h.pkg.tar.xz )
Ban thu lai xem sao !
Xin loi nhe vi dung may cua Cty nen khong co font tieng viet !!!
