Ðề: TV Movies Card
Giới thiệu cho bác vài loại thông dụng rẻ tiền:
01. Aver EZ Capture-PCI
Giá cỡ 700k VDN.
02. Kodicom KMC-8800 Video Capture Card
Giá cỡ 1 củ.
03. PINNACLE STUDIO 510 USB
Giá cỡ 2 củ rưỡi.
Nơi mua và cách sử dụng bác google nhé!
Cấu hình máy tính: - Intel Pentium Dual E5200 2.5GHz (2M - 800FSB)
- Intel Chipset G31/ICH7
- DDRII 1GB
- HDD 160GB SATA
- VGA & Sound card on board
- 8x USB - Lan 10/100
thì có sử dụng được card Aver EZ Capture-PCI hoặc Kodicom KMC-8800 Video Capture Card? Hai con này có hẹn giờ record? Chất lượng record có ok không bạn?
Có người giới thiệu với mình loại card này: AVerTV Hybrid+FM Volar HX
Thông tin chi tiết của sản phẩm
Major Description
Streamlined, sleek, and spectacular AVerTV Hybrid+FM Volar is your considerable solution for both Notebook and Desktop PCs to simply switch from viewing Analog TV to Digital (DVB-T standard) with just one click during the switchover process. Moreover, the AVerTV Hybrid+FM Volar with USB interface and the connected antenna provide you the ultimate portability to experience mobile TV entertainment wherever you are, whenever you want!
Feature
4:3 and 16:9 Wide-screen Format
16-Channel Preview
Multi-User Setting
Auto-Scan & Full Channel / All Frequencies Scan
Over-Scan
Fully Resizable TV Windows (1/4 to full screen)
Channel Re-mapping
Digital Subtitle Support
Enables to choose when you want to watch subtitles and even to select the language in which they appear
MHEG-5 Support (UK Digital Teletext Service)
Allows users to access the UK's range of digital teletext services on their PCs to provide a complete entertainment experience.
Video Quality Enhancement
Provide more vivid and vigorous picture quality with less noise and jitter.
PVR (Personal Video Recorder)
TimeShift
TV Scheduler (One-time/Continuous Mode)
Silent Record (Mute While Recording)
Record Video in MPEG-1/2/4* formats
Sequential Snapshots (Single/Consecutive)
Wake-up Recording from Stand By (S3)/Hibernate (S4) Mode
Fast Channel Switching and Scanning
Specification
Input Signal
75 Ω TV Antenna
Composite (RCA)
S-Video
FM Radio Antenna
System Requirement
For TimeShift and Record in MPEG-2
- Pentium 4 2.6GHz (Hyper-Threading)
- AMD Athlon XPR 2600+
- Pentium MobileR 1.73GHz
VGA Card Supports DirectX 9.0c
256 MB RAM or above
USB2.0 Port
Sound Card
Windows 2000/XP/Linux*
Windows XP MCE(DVB-T only)
For HDTV Only
- VGA card supports DirectX 9.0c and DxVA (HDTV)
- HDTV will only function when the TV signal is in HDTV format
*Please refer to our support website for instructions.
Package Included
FM Radio Antenna
Installation CD
S Video / Composite 2 in 1 Cable
Quick Installation Guide
MMCX to RF Cable
USB Cable
Remote Control (batteries included)
cấu hình máy tính nêu trên có sử dụng được card này? card này record có ok không bạn?
Cám ơn bạn.
